SailNet Community - View Single Post - Looking for Fixer upper Cruising Sailboat
post #5 of Old 02-16-2003
slipacre
Searching boatyards near you is probably the best bet as suspect that you will have to work on her where she is before you can move her to a more convenient location. They are out there - and although you can save much $ by doing yourself - be prepared for some expensive parts and have a lot of time available. There may be a good reason that the boat was abandoned. It is very easy to put more money into a hulk than it will ever be worth. You might also look for slightly more expensive boats with less expensive fixes.
Also realize a variety of skills may be needed from carpentry to mechanic to rigger to fiberglassing.
good luck todd
slipacre is offline
