Large cockpits and the big glass doors are still a problem on catamarans IMHO... I would not like a big open cockpit, without sufficient drains or a big glass wall between the cockpit and the interior, that didn't at least have some provision for storm covers of some sort.
However, one thing monohull sailors don't realize is that a properly designed multihull tends to stay on top of the waves, and isn't hit the same way a monohull generally is, mainly due to the fact that they don't have several thousand pounds or more of ballast trying to pull them under the surface.
Being pooped isn't that big of a problem, from what I've seen on most multihulls.
Originally Posted by sab30
Dog - Out of ignorance can you answer a question for me. With monohulls they are always stating to watch the cockpit size for alot of offshore work as following seas and breaking waves could become a problem...when I look at multihulls I usually see what appears to be a large patio door just forward off a large flat deck...isnt this a nightmare scenario for large following seas of am I misunderstanding the design and physics regarding a multihull boat...all I can see is a large wave crashing through the door..
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
