Originally Posted by whroeder
When patching a large area in dry wall, the trick is to place one or more small boards behind the wall with a temporary line to a board on the front. Then the patch can be placed in and the outside spackled.
How about the same: Epoxy the edges and a backing. Remove the front support. Fill and finish.
Great dry wall tip, but you misread the OP's question. He is re bedding deck fittings, not patching holes.
