Old 01-21-2008
jrd22's Avatar
jrd22 jrd22 is offline
Courtney the Dancer
jrd22 is on a distinguished road
Let me explain further. I know how to pot regular holes with epoxy, the issue here is that I have three 4"X8" by 1 1/4" rectangles and I just want to fill around the edges about a 1/4" with epoxy, I would rather not have to figure out how to support it on the bottom and fill the whole thing with epoxy and then cut out 95% of it and throw it away. I thought about removing about 1/4" of core all around and then using duct tape to seal the edges all the way. I could inject epoxy through 1/4" holes drilled around the top edges, but I wouldn't be able to thicken it much at all if I had to use a syringe to inject it with. I also wouldn't end up with straight edges because the duct tape would bulge out somewhat, although that probably isn't a big problem. The other option, like Freesail suggested, is to just paint the edges with epoxy and bed the prisms well. Thanks for your suggestions.
John
John Davidson SV Laurie Anne
1988 Brewer 40 Pilothouse
