SailNet Community - View Single Post - Being Hit By Lightning - To Ground or Not
  #22 (permalink)
Old 01-23-2008
coatiac coatiac is offline
coatiac is on a distinguished road
Lightning
My 2 cents as an electrician are that most damage caused by lightning strikes are due to a poor or improperly sized ground path. The best example I can give is when the stike happens to an "ungrounded" mast. Of course there are conductors up there, the mast being the best one, but if it isn't properly grounded, the the strike will usually start with a light or antenna wire, because there is a connection to ground with these circuits. But as soon as the strike is iniated, the small conductor will fail at some point, leaving the strike to find a new path, which then becomes the mast until arriving at the base, where it then jumps to the next closest conductive material. It is the failing of one path, and subsequent jumping to the next path that causes the damage.
Ground your sticks properly, keep the paths as atraight as possible, and keep your connections maintained.
