SailNet Community - View Single Post - Being Hit By Lightning - To Ground or Not
  #25 (permalink)
Old 01-23-2008
sailingdog sailingdog is offline
NWR-
The 2AWG jumper cables probably did less than zip to ground your boat, given the high resistance of the stainless steel used in shrouds and stays, and the low surface area of the clamping method... it was of almost purely psychological benefit if anything.
Chuckles-
The grounding strip/plate for a lightning bond system does generally have to be a bit heavier than most foils are. The best ones I've seen have threaded copper studs that go through the hull to the bonding system.
