Thread: Propwalk
  #39 (permalink)
Old 01-23-2008
cardiacpaul's Avatar
cardiacpaul cardiacpaul is offline
MarineSurveyor
cardiacpaul has a spectacular aura aboutcardiacpaul has a spectacular aura aboutcardiacpaul has a spectacular aura about
"The worst boat that I've been on is the Catalina 27, it can do circles without end. The rudder is a little small in size, and not very deep.
If you are not sailing one design, you could have a new rudder designed and installed that would reduce most of the prop walk, but not eliminate it.
It really probably wouldn't do a thing... Catalinas - whether you have 27 or 30+... the rudder simply doesn't encourage being in reverse unless you master the propwalk - and even then - its not a sure thing... "
I'm not sure about your 27, but the rudder on mine was about the same size as a garage door.
Propwalk on her was a feature! The "trick" is you have to get a little water moving across the rudder BEFORE you give it a shot from the throttle. If you don't you're going nowhere, slowly.
We are not primarily on earth to see through one another, but to see one another through
Some people are like slinkies: not really good for anything... but you can't help laughing when you push them down the stairs
