A 1/8" plate of copper that is 2" x 24" isn't all that heavy..
You could install two of them and probably never have to replace them again. Have them installed with five 1/4" x 20 copper studs attached...and you'd be good to go. However, how you get from the mast, to the underwater part of the boat on a catamaran without encouraging sideflashes is a neat trick.
A trimaran is a bit simpler... and I'm planning on getting a strip made up for my boat.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
