Originally Posted by GBurton
If the hit was on the capshroud then it is being conducted right? And then you would want a way to take it to your "ground"
Wouldnt the shroud be a better conducter than the fiberglass deck?
You might want to check out that article I linked to. It explains the heat generated in a 8 ga. Cu wire and why such a wire is inadequate. The same would likely be true for the clips on the cables and the shrouds themselves, for that matter.
