Thread: engine trouble
Old 01-23-2008
jrd22's Avatar
jrd22 jrd22 is offline
Courtney the Dancer
I agree with JohnPollard above. If the gasket on the raw water pump is leaking it can and will suck air in and possibly fail to draw water in. Put some sealant on it and try again, if it still does not prime follow the other instructions that have been given here. Start at the seacock and make sure you are getting water, then check strainer and on through the system.
Good luck, John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
