SailNet Community - View Single Post - Where should I start?
post #7 of Old 01-26-2008
sailingdog
No reason you shouldn't be able to learn to sail on a boat that size. A smaller boat would give you a bit better feedback in terms of sail trim and boat balance, but that shouldn't affect your ability to learn on your boat. I'd highly recommend that you take, at minimum, an ASA 101 type basic keelboat handling course, since that will give you the basics and give you a pretty good idea of what you need to learn to at least get safely started.
I'd also recommend you get Dave Seidman's The Complete Sailor, which is by far one of the best books for novice sailors, and is quite easy to read, yet covers a fairly broad range of sailing topics.
I'd also recommend you read this post get the most out of your time on sailnet.
sailingdog is offline
