  #14 (permalink)
Old 01-28-2008
Sapperwhite's Avatar
Sapperwhite Sapperwhite is offline
Not So Senior Member
Sapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura about
Originally Posted by poopdeckpappy View Post
One last question, What would be the advantage of a 2 gal over a 1 liter Acc. tank of better yet why would I need or want a 2 gal acc tank
A larger accumulator has more capacity to keep pressure on the system, it will keep the fresh water pump cycles down. However, to pump the system back up to normal pressure the pump may run a little longer when it does come on. If you get a bigger accumulator you may just need that bigger pump after all if you don't want the pump running for a whole minute just to get the system back up to pressure.
You may prefer stainless to plastic accumulator (or the other way around). Space to install a larger tank may be a consideration too. Cost considerations come with quality and material (as always). There are a few manufactures out there also: shurflo, jabsco, grocco, and a few others.
My system is small and simple, I only need a small accumulator, a small pump, and a small water heater. If you have an elaborate system or maybe a few people using it at the same time (washing dishes while you shower), you may need bigger components.
Dictated, but not read.
