Obviously an incomplete list, since it doesn't have a lot of multihulls that have been used for LD cruising. If the PDQs are on the list, there's no reason the Maine Cats, Geminis and several others in that size range shouldn't be on the list. There are a fair number of trimarans that also would qualify. Several of the Farrier designs, the larger Corsairs, the larger Quorning Dragonflies should also be on the list.
