You're better off with polyester webbing, since the polypropylene is much weaker and much more subject to UV degradation... The stainless steel ratchets are usually not marine-grade stainless, and will need to be washed down regularly and sprayed with WD-40, Boeshield T9 or something similar. BTW, nylon tends to stretch a lot more than polyester, especially when wet... so if you strap something down with the straps wet...and they dry out, you may have a problem... and vice versa.
If you're new to the Sailnet Forums... please read this POST.
