Peteramc,
Lotsa good advice in the above (esp. Camraderie and Billyruffin); also some questionable stuff in other posts.
A few suggestions:
1. Re-read Cam's and Billy's comments and heed that advice.
2. There's nothing inherently wrong with using 6V batteries. In fact, it's the preferred way for many cruisers due to cost, efficiency, weight and ease of carrying, space, capacity, etc.
3. Wired correctly, there's also no problem with creating a single bank with batteries located port and starboard. Mine have functioned just fine that way for over 15 years (total of six 6-volt T-105s).
4. There's no chance of "thermal runaway" because of separated batteries; that's pure bunk. However, it IS a good idea to keep batteries as close together as possible to keep wiring runs short.
5. People tend to underestimate the size wiring needed to wire batteries together, be they 12V or 6V or whatever. Always use a heavy guage cable, 1/0 or larger, even if your batteries are close together.
6. The use of a single large battery bank for house plus a separate starting battery is the current preferred method, for several very good reasons.
7. You don't need to have them on a 1-Both-2-Off switch. A better arrangement for many installations is a simple ON-OFF for each bank (i.e., for the house bank and the starter battery).
8. Charging sources on a moderate or large-sized cruising vessel should all be wired directly to the house bank (not the starting battery). Use a battery combiner or, better, an EchoCharge device for keeping the starting battery topped off.
9. DO NOT think about keeping a battery "in reserve". Batteries deteriorate from the moment they leave the factory, due principally to lead-sulfate buildup on the plates caused by less than full charging and use. A battery sitting idle is a battery going bad.
10. Battery failures in a properly designed system are NOT all that common. You don't need to carry a spare battery.
11. The charging methods used are absolutely critical. There's a lot of info on this board and others (esp. SSCA board). Short version: be sure you have a modern 3-stage charger and leave it on. Very good chargers which are cost effective are the Iota series from Iota Engineering. They make models from 15A to 90A which use high-tech charging methods which extend battery life.
The advice in a previous posting to seek the counsel of a marine electrician is good. It can save you lotsa heartaches and $$$ in the long run. Batteries are expensive; wire prices are out of sight; and an inadequate or poorly designed electrical system can be anything from an expensive headache to a disaster.
JMHO,
Bill
