Old 03-09-2003
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Super Moderator
Vee shaped Holding Tanks....To pick up some space.
The best source for holding tanks in any shape is RONCO Plastics. RONCO makes holding tanks in wide range of shapes and sizes and are priced quite reasonably. They are purchased direct order and can be gotten in a number of possible configurations. My best advice is to order the tank with top mounted inlets rather than the usual combination of top and bottom mounted inlets. I also recommend having the factory install the 90 degree elboes intragal with the inlets and outlet rather than as separate fittings. Ronco is available
http://www.ronco-plastics.com/
