SailNet Community - View Single Post - Gyb’Easy
Thread: Gyb’Easy
post #20 of Old 02-03-2008
teshannon
teshannon's Avatar
With the Gyb Easy you set the tension with the number of wraps. If you set sufficient tension to slow down the boom movement does that make normal mainsail adjustments harder? With the Dutchman you can adjust the tension from the cockpit but it seems with the Gyb Easy you have to re-rig. Am I correct?
teshannon is offline
