Teshannon-
Just be aware that you'll probably have to tweak the setup a bit to get the exact position of the boombrake mounting point right. The way I did it was by setting it up on a sliding padeye and then used a line to adjust the position until I found the one that worked best. On my boat, these padeyes slide along a track along the bottom of the boom.
