Thread: Keel Design
Old 02-06-2008
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
This was written for another venue but represents my take on encapsulated vs bolt on keels:
This is another one of those ‘no one universally right answers’ questions. In other words an argument can be made for either type of keel. (For the record, I personally strongly prefer a bolt on keel rather than an encapsulated keel.) Here’s the way I see it.
Bolt-on keels tend to offer more performance since the ballast must be cast and without the keel stub skin thickness tend to have a lower vertical center of gravity relative to the center of bouyancy. They also have significantly less wetted surface and frontal area making them theoretically faster on all points of sail. They are simple to repair and generally can be repaired satisfactorily no matter how bad the mistake.
On the down side they are more expensive to build; requiring precision casting, bolt hole drilling and a lot more hand fairing. They are higher maintenance requiring fairing every 10 years or so and new keel bolts at some point in the boat’s life.
Encapsulated keels are less expensive to build. There’s less labor and less precision required. Boat builders will often use less expensive forms of ballasting with encapsulated keels, such as iron or lead scrap cast in concrete, resin or other binder further reducing costs. If they are not damaged in a grounding, encapsulated keels are less expensive to maintain.
On the down side they are less efficient. Their real downside is the difficulty in doing a proper repair. Typically, in a hard grounding a number of things happen on an encapsulated keel. Typically the skin of the keel encapsulation gets ruptured and separates from the ballast. This allows water into the small cavities between the keel and the ballast and once wet it can mean the ‘beginning of the end’ for the boat as this permanently wet fiberglass blisters itself from the interior and the wet areas spread around the ballast. This is especially a problem on a boat that is hauled out for cold winters where freeze/ thaw cycles can really pry the skin loose from the ballast. The problem gets worse when the ballast contains ferrous materials. Here the ballast begins to rust and can reduce the ballast into a loose mass of matrix and rusting iron.
Beyond that, in a grounding the ballast is often forced upward as well. In an encapsulated keel the membrane of the hull is at the outside of the keel and the membrane above the ballast is often quite thin. In a bad grounding the ballast keel is often is pushed through this membrane causing a serious and difficult to repair damage and leak.
We grounded a boat with an encapsulated keel that we never could permanently fix for as long as we owned the boat. The problem would get worse with every year, spreading from a small dimple on the leading edge of the keel to an area that was much of the bottom and sides of the keel.
Lastly, it is very hard to lay-up the glass in the keel cavity. As a result the glass work in this vulnerable area of the boat is often inferior to the glass work else where on the boat.
