Old 03-18-2003
nauticalrich's Avatar
nauticalrich nauticalrich is offline
nauticalrich is on a distinguished road
Sea Water Pump Impeller
As recommended for winterizing my Universal 14 HP diesel, the manual suggested removing the raw water (sea) impeller. It stated be careful not to pull the shaft out when removing it. I put a screwdriver against the shaft and pulled the impeller off. Unfortunately I did slightly move the shaft but just a little. It went right back in. It was sort of a jerking motion, real quick and very short.
They state if you pull the shaft out by accident you have to remove the pump and realign it etc. However, I can''t turn the shaft at all by hand so it must be still properly seated (I hope).
I guess the question is for anyone knowledgeable to tell me it''s ok????????
Its an Oberdorfer pump.
