SailNet Community - View Single Post - Easy Question
Thread: Easy Question
post #4 of Old 03-19-2003
Jeff_H
Moderator
Jeff_H's Avatar
Easy Question
You''re right, the weight of sail can significantly raise the boat''s center of gravity, one reason that instrumented full sized cruising boats often have significantly less stability than a simple stactic analysis might imply. As you note this means less stability, both initial and ultimate. It also means more rolling through a wider angle and with that the likelihood of an excitation capsize. Increased rolling also hurts performance by disturbing the airflow across the sail.
Jeff_H is offline
