SailNet Community - View Single Post - Rubber = Galvanic Corrosion?
post #1 of Old 02-09-2008 Thread Starter
sailboy21
sailboy21's Avatar
While browsing the web for boat stuff (what else?) I ran across a fuel tank manufacturer that issued a warning not to use rubber in contact with aluminum. The reason stated, was rubber contains carbon which exists on the galvanic series, and is slightly more noble than passivated stainless steel.
I immediately thought of my stainless steel masthound for my inner forestay.
I had placed a rubber gasket to insulate the stainless from the aluminum. It had never occurred to me that I may have been creating a bigger galvanic cell! I removed the masthound and found zero evidence of corrosion after two years.
Has anyone heard of an issue with rubber against aluminum? I usually use HDPE as an insulating material, and religiously use tefgel on fasteners, but I had a sheet of generic black rubber gasket material handy at the time. Should I replace the rubber with a sheet of HDPE or leave it alone?
sailboy21 is offline
