SailNet Community - View Single Post - Pulled out old foam back vinyl from berths...what now?
post #5 of Old 02-13-2008
mjrogers
There is an article in the most recent Good Old Boat about using foil faced foam insulation board wrapped in fabric. The auothor used it successfully on compound curves. You should probably fix the remaining leak before using any type of panel, upholstery, or fabric. Otherwise you will just be farming mold. If you can't track down the last leak, paint may be the best option.
mjrogers is offline
