SailNet Community - View Single Post - Crimping versus Soldering
Old 02-14-2008
Maine Sail's Avatar
Maine Sail Maine Sail is offline
Cd..
That has been my experience too. I've re-wired my fair share of boats over the years and without question the soldered joints are the ones to fail, corrode or both.
The other thing I've found is the wires tend snap just above the solder joint. This is probably due to solder creep which makes the wire more brittle because it's now, in a sense, a single conductor wire and has lost it's multi-strand flexibility.
I do a two part process, crimp /heat shrink with a proper marine grade adhesive lined heat crimp terminals usually made (or sourced) by Anchor, FTZ or AMP.. This become a hermetically sealed joint..
______
-Maine Sail / CS-36T
