SailNet Community - View Single Post - Crimping versus Soldering
Old 02-14-2008
sailingdog sailingdog is offline
I've seen soldered joins fail, and often far sooner than a properly installed crimp with adhesive-lined heat-shrink will. As Halekai has pointed out, they're far more subject to fatigue than a properly crimped join would be, since the solder does effectively convert the nice flexible strands into a single solid stiff wire.
A bunch of hints to making a crimped connection that will last.
First, use a good ratcheting crimping tool, which will allow you to apply fairly consistent pressure on all of your crimps. Non-ratcheting crimpers will not give a consistent amount of pressure on the crimp.
Second, use good marine-grade crimp terminals—non-marine grade ones will corrode out rather quickly.
Third, use good marine-grade tinned wire. Marine grade wire is pre-tinned, and has more, finer strands, for greater vibration fatigue resistance.
Fourth, use a decent adhesive-lined heat shrink tubing. The adhesive lining is what really makes the connection waterproof. Don't skimp on this step.
