Old 02-14-2008
sailingdog sailingdog is offline
Degrading the insulation doesn't probably make it caustic...but it probably does make it more porous, leading to moisture getting in and kicking off the corrosion process.
Some insulation might be PVC-based and as such, heating it might release Hydrogen Chloride gas...which when added to water becomes Hydrochloric acid.
