SailNet Community - View Single Post - propshaft removal
post #3 of Old 03-01-2001
Denr
Senior Nappy Headed Ho
propshaft removal
patc:
A tool is made that allows cutlass bearing to be removed without the need to pull the prop shaft. You must however remove the prop when using the tool, obviously. The boat yard used this tool to replace my bearing 2 years ago, I suggest you bite the anode and pay someone to do it with this slick tool. Mine cost about $100 for the 1.000" shaft.
Denr is offline
