Not just vibration, but occasional access to panels, or the occasional tug on the harness will cause enough mechanical fatigue in a solder joint to cause it to fail. Soldering requires a long list of prerequisite conditions to create a satisfactory joint, and even then, as mentioned you have created a solid strand vice multistrand. That alone is reason enough not to solder. You don't use solid wire on a boat for the same reason.
