SailNet Community - View Single Post - Crimping versus Soldering
post #57 of Old 02-16-2008
artbyjody
artbyjody's Avatar
Originally Posted by werebeagle View Post
I've worked on some houses where that was the thought also. The connection was so reliable, that they decided not to put it into a junction box, but just bury it behind the drywall.
I have too - and will do it if in a pinch - but nah either the crimping or soldering - both actually if done properly with the right materials imho work equally as well... the problem with crimps is there is one moisture point ingress unless the heat shrink cover where the spade starts....it doesn't take much and the crimp will outlast the wiring any day as it doesn't suck moisture...my last post was merely in jest....
-- Jody
S/V "
1983, Barberis Show 38! or
artbyjody is offline
