SailNet Community - View Single Post - Budget Cruising/Bluewater Cruising
post #3 of Old 02-17-2008 Thread Starter
Cruisingdad
Best Looking MALE Mod
Cruisingdad's Avatar
I will not be able to provide a lot into what makes the best boat to go on, as I opt for more of the creature comforts a small boat would not be able to handle.
Things that are important, in any bluewater/cruising boat, in my opinion, are:
1) Tankage. THis is especially true for water.
2) Good seaberth.
3) LOTS of storage, with a lot of that being below the waterline. We take a lot of can goods... others may not. But there will be many things you carry that add negative stability if above the waterline. This will likely be more of a factor on a small boat.
4) A well draining cockpit. I have been pooped once, and should have been who knows how many times before that. I think this is imperative as the time it happened to us were were only 24 hours/120-130 miles from shore.
5) Some method of cooking. I would probably put this as a critical system.
6) Decent lazarette for sails and gear.
7) Windvane or autopilot or the ability to put it on. You cannot make a passage without it if you are singlehanding... at least not safely. I would put this as a critical system too.
8) A SOLID, DRY Cabin with high-end portholes and hatches (the latter if going offshore).
9) Deep bilge and an electric bilge pump. I feel the latter is a mandatory - though this will require a battery. I guess the elctric bilge pump could be debated??? Thoughts?
10) VHF? I feel a handheld is the very minimum. However, could it be debated that you have to have a base unit?? The power/receive will be vastly better. Thoughts? This requires a battery.
11) Intl/Colreg recognized lighting. Mandatory... but could you get buy with a solid white light powered by lamp oil?
12) Sextant, and the ability to properly use it.
13) Charts... paper, not electronic.
14) Radar reflector. I feel this is madatory. Others will dissagree.
I am trying to think of a way around batteries, and an engine. I think you can get by without an engine. I am not positive about the batteries. Unfortunately, if you have a battery, you are now forced into a way to charge it. THat means solar (expensive), wind (unreliable and marginally expensive), or an engine (which now is maintenance, weight, fuel, spare parts, etc).
THoughts???
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
