Old 04-01-2003
h37skipper h37skipper is offline
h37skipper is on a distinguished road
Rudder Post Problem
Are there any surfaces inside the boat that would support a bushing? If the rudder stock goes through any supports you could put one inside. These can be made as two halves to clamp around the stock so the boat and rudder do not have to be pulled. Clamp it around the stock against the bottom of the support and the rudder cannot "float" up against the hull.
