SailNet Community - View Single Post - How much battery power / capacity
post #2 of Old 02-18-2008
sailingdog
Petar-
The batteries aren't probably in all that bad a shape. A fully charge 12 VDC bank, even one made up of four T105 GC batteries, in two sets of two, will only be 12.6-12.7 VDC at 100% charge. Depending on what kind of lights and stereo you have, it could very well be that you drop them from 12.6/7 to 12.3 volts in two hours.
Letting them dry out was probably not very good for them. What I would recommend you do before biting the bullet and buying new batteries, is to get a good hydrometer and charge the batteries fully, then disconnect the cables and let them sit for an hour or so... then check the individual cells to see what the specific gravity is of each cell. If they're all about the same and come up as fully charged... They're probably okay. It might be that one of the batteries has a bad cell, and that would bring all four down rather quickly.
sailingdog is offline
