Originally Posted by olysailor
I had the bottom cleaned and there were muscles on the prop. I went out this weekend and the motor ran fine no slipping... Also the water was coming from my stuffing box which was an easy fix it just needed tightened..
Tightening the stuffing box is fine short term, too tight and you'll groove your shaft. While out of the water you should always plan on repacking the gland.
