SailNet Community - View Single Post - long or short shaft?
post #2 of Old 04-10-2003
foxglove
foxglove's Avatar
The only reason I have used long shafts is to keep the prop in the water when rolling over large waves which is a problem with transom mounted outboards. I would guess that if your engine well is sufficiently forward of the transom and you don''t think your prop will lift above the water in rolling seas then either shaft length would work.
foxglove is offline
