So, if I:
1. Run a single wire, rated for the full amps expected, from a single cabin lights switch to a 5 gang fuse block.
2. From one of those set of posts run a single duplex wire to the first fixture both pos and neg.
3. From this same fixture run another wire to the next fixture and so on. This would essentially be a 3 wire splice, right?
4. Keep doing this until I reach the end of the port circuit.
5. Repeat for starboard circuit.
You will regret the things you did not do, more than the things you did.
Get out there!
Saco Bay, Maine
1971 Ericson 29
