Duffer—
I was specifically responding to when you said
There isn't one seperate pair of wires running to each light, that would be a boat-load (sorry for the pun, I couldn't resist) of wires!
in a previous post. If you used a buss bar, fuse box, or switch panel setup, like I did, you would have separate pairs running to each light.
Originally Posted by duffer1960
Sailingdog, I didn't think lights would be wired in series, there would be too much of a voltage drop across each light, and they would be too dim; but I guess there may be an application for that. Also, if there was a switch in any fixture in the series application, opening that switch would shut off every light in the circuit.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
