  #29 (permalink)
Old 02-26-2008
sailingdog sailingdog is offline
This is only true if you've wired the circuit with wire of a heavier gauge than necessary for the load and run length. Generally, I prefer to oversize the wiring on my boat by a bit...going up a size in wire gauge, since oversized wiring is generally not the problem undersized wiring is, and it reduces the voltage drop at the terminal end as a bonus.
Originally Posted by xtatico1404 View Post
One of the branch circuits has a Rule 360 bilge pump, which draws 2.1 amps and will probably be wired with a #18 gauge (not taking into account voltage drop, wire length, bundling or any other de-rating issue). Outside of engine space, a #18 will give you 20A according to industry tables. The fuse or the breaker is a 2.5 Amp. The reason behind it being fused to the load on the branch circuit is that if you have a short circuit of say 18 Amps, and your breaker/fuse was 20Amp, the breaker will not protect the load. However, if you fuse to the load, with a 2.5Amp fuse, you will be protecting BOTH the load and the wire.
So, in branch circuits, you size the fuse/breaker to the load.
