SailNet Community - View Single Post - 1990 Johnson 3 hp outboard
post #3 of Old 02-26-2008
SVDistantStar
'72 Pearson 36
SVDistantStar's Avatar
Send a message via AIM to SVDistantStar
Another quick hint of advice on that motor. Ive found that if you screw the mixture screw in all the way and then back it out 1-1/2 turns it will pretty much always run right. Sometimes a little bit of tweaking is needed, but in most cases its not.
I will say that you've got a good little motor, but if you have never run one of them, your in for a little surprise as it has the power of most 5hp motors being a twin cylinder. Just remember its got points for the ignition, so keep them clean and shiny.
1972 Pearson 36 S.V. Distant Star
SVDistantStar is offline
