Old 02-26-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
If you have gone to all the trouble of pulling the engine, you really should do more than "just clean it up". At a minimum, I'd have your brother do b,c, and d while it's out. Otherwise you may be re-installing an engine with little life left in it, or not, but you just won't know.
With a larger engine, I would expect that you'd need to re-prop (size and pitch). If you do go that route, this would probably be a good time to replace the shaft rather than re-use the old one.
If space is tight, the Beta equivalent is about 1.5 inches shorter and 1 inch narrower than the Yanmar.
I would suggest you peruse some of the re-powering threads here on Sailnet. There's usually quite a bit more to it than simply swapping the engines out....
