While this may be true, you still really shouldn't be soldering connections on a boat for many other reasons.
Originally Posted by chjensen
Soldered joints failing is always due to improper technique,
This is the way to do it right and make soldered joints last.
-Use a heat shrink so the solder and flux doesn't run up the wire (under the insulation
Use good quality solder (with flux inside)
after you solder the wire - wash off all the flux residue with alchohol - this is a critical step as water+flux=acid and will corrode the wire quickly if left on.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
