  #11 (permalink)
Old 02-26-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Fighting the current is generally a losing proposition in a sailboat, which has a relatively low top-end speed to begin with. If the current is running at 5 knots against you, and you can only make 6 knots... the chances that you get into trouble are a lot higher than if you're trying to make the same passage at slack tide. A lot of the boats that make those passages against the current have a lot more horsepower and much higher top-end speeds... making a passage into a 5 knot current is much simpler in a boat that can do 20-30 knots as a top-end speed and has 10-30 times the horsepower you do.
If you're new to the Sailnet Forums... please read this POST.
