  #13 (permalink)
Old 02-27-2008
puff6022 puff6022 is offline
puff6022 is on a distinguished road
I found the problem, On a strong starboard tack (my thru hull is on the starboard side) the thru hull comes out of the water allowing the hole system to drain and loose prime. I am going to install a check valve between the thru hull seacock and my raw water strainer. I've had the boat since 2001 and never had the problem until now. I just replaced my sails, and therefore heel more. Thanks for all the input.
Puff
