SailNet Community - View Single Post - Crimping versus Soldering
post #87 of Old 02-29-2008
Maine Sail
Maine Sail's Avatar
Re: Crimping
Originally Posted by rhedrick View Post
I think important suggestion, related to the one response that I caught regarding the moisture point of entry where the heat shrink doesn't quite close up the gap between the spade (or loop), which is a very common problem.
If you use a quality factory made heat shrink connector this will almost never happen. I've used perhaps thousands of these factory made heat shrink connectors at this point and I always inspect them after the termination is made and I've yet to see more than a very low percentage perhaps .2% had the gap or point of entry you describe.
The heat shrink material that comes on the factory made terminals is much thicker and far more robust than the adhesive lined heat shrink you can buy off the shelf.
Notice the glue oozing out of the ring end of that terminal.
______
-Maine Sail / CS-36T
Maine Sail is offline
