SailNet Community - View Single Post - Head Problem
Thread: Head Problem
Old 04-21-2003
bjoc2314 bjoc2314 is offline
bjoc2314 is on a distinguished road
Head Problem
We bought a 2001 Catalina 310 near the end of last season so this was our first launch. The head, which worked fine in the fall, is not pumping in seawater, I have the thru-hull valve open and the head in "wet bowl" mode, but nothing happens. "Dry bowl" mode seems to work fine.
I suspest the problem is the Wet/dry bowl switch/valve. Any suggestions on a solution or cause of the problem would be apprecaiated. Thank you
Brian O''Connor
Catalina 310 #151
Anam na Mara
NY, NY
