  #66 (permalink)
Old 03-01-2008
Omatako's Avatar
Omatako Omatako is offline
Omatako will become famous soon enough
John Vigor's black box theory
As an extenion the my earlier thread, this is pretty much what I meant (quote from John Vigor):
In the Freelance corollary to the theory, every boat possesses an imaginary black box, a sort of bank account in which points are kept. In times of emergency, when there is nothing more to be done in the way of sensible seamanship, the points from your black box can buy your way out of trouble. You have no control over how the points are spent, of course; they withdraw themselves when the time is appropriate. You do have control over how the points get into the box: you earn them.
For every seamanlike act you perform, you get a point in the black box. Points come in so many ways it would be impossible to list them all. But I can send you in the right direction. Let's say you're planning a weekend cruise down the coast, and time is precious. You have been wondering for some weeks if you ought to haul out the bosun's chair and inspect the masthead fittings. It has been a couple of years since you checked everything up there, but it would mean delaying your departure by an hour, maybe more, should you have to change a shackle or something.
If you finally give in to the nagging voice inside you and go aloft, you earn a point in the box. If you don't take that trouble, your black box will stay empty. If you sniff the bilges for fumes before pushing the starter button, you'll score a point, just as you will for taking a precautionary reef at nightfall or checking the expiration date on your rocket flares. Thinking and worrying about what could happen is also a good way to earn points - what if the wind started blowing into your quiet anchorage at 40 miles an hour and the engine wouldn't start, or whether you should put a couple of reefs in the mainsail before you climb into your bunk, just in case.
No matter how good your seamanship, there are times when there is nothing left to do but batten down the hatches and pray. If you have a credit balance of points in the box, you'll be all right.
As said in my earlier post, Gene must have had a "credit balance" .
Andre
