Hello All:
Glad that you were able to figure out that it is a ramrod for your centerboard, should it become stuck. We have had a Sabre 38 w/centerboard since 1990, and never had a problem w/ our board not dropping when needed. However, last summer a centerboard version of the Sabre 36 in our charter fleet did have the board get stuck in the "up" position. After releasing tension on the centerboard winch, upcapping stainless steel cap nut in boat bilge, and enjoying a great Roman fountain for a brief period in the main salon, we tried to use this device to push the board down, but to no avail. Cause was actually a few mussels which had broken free from inside the trunk and became lodged alongside the board. Short haul and some long thin prods allowed the board to fall. Incidentally, you can move the rubber hose if more or less length is required, but it is there to keep one from losing the rod through the bottom of the boat. I hope that this experience sheds some light on this mystery Sabre apparatus! Fair Winds!
