SailNet Community - View Single Post - tohatsu 3.5 won't run without choking
post #8 of Old 03-03-2008
camaraderie
moderate?
camaraderie's Avatar
I agree that the carb bowl and float are the likely culprits if you have good flow up to that point. It is pretty straightforward work to disassemble and clean and does not require a manual if you just go slowly and try not to have any pieces leftover when you put it back together!
camaraderie is offline
