SailNet Community - View Single Post - Head Problem
Thread: Head Problem
Old 04-23-2003
h37skipper h37skipper is offline
h37skipper is on a distinguished road
Head Problem
Easy to check. Remove the inlet hose at the head. Open the thru-hull or, if it is too far away, have someone open it. If water comes out of the hose then the valve is bad. My guess is that the hose, thru-hull, or seacock is clogged. You should have a filter on that hose, right after the seacock or whatever kind of valve you are using.
