Stupid engine question
You''re fine. A diesel engine ignites the fuel by compression, not spark like a gas engine. That''s why the engine will not run in the decompression mode. I use the decompression mode if I am working on the diesel and have to turn it over by hand. As far as the dipstick goes, you need to get it removed. you can''t measure the oil by looking into the filler. Keep in mind that the oil is in the oilpan under the engine while the filler is at the top.
