Old 03-04-2008
sailingdog sailingdog is offline
I wouldn't strip the cover, even if it is a bit heavy. The cover acts to protect the inner core from UV damage and abrasion.
Originally Posted by jimmyb116 View Post
I would suggest stripping the cover, as it is heavy on warp speed and not required for the halyard, just leave enough cover so that when the sail is fully hoisted the cover stops at the mast base. Also Use the splicing instructions from the Marlow site much stronger eye splice. Don’t forget to lock stitch or it will creep on you.
